merc freshwater flush
Old 01-27-2014 | 08:14 PM
Default merc freshwater flush
I want to run my 2005 merc 502's on the hose…. but can't find where to put the hose… do I need an after market fitting??
thanks
way2fast is offline
Old 01-27-2014 | 08:18 PM
If its on the trailer just buy the ears that go on the outdrive.
Crude Intentions is offline
Old 01-27-2014 | 08:29 PM
Flush muffs and foam ear plugs for the low water pickups.... And I only boat in freshwater. It's not that I hate my neighbors, I just like noisy motors.
Speedracer29 is offline
Old 01-28-2014 | 05:14 AM
its running original TRS outdrives so no pickups in drives… therefore ear muffs no good
way2fast is offline
Old 01-28-2014 | 06:52 AM
where do you pick up water from?
HyFive578 is offline
Old 01-29-2014 | 05:42 PM
central scoops at bottom of Vee?
way2fast is offline
Old 01-29-2014 | 06:29 PM
32hustlin's Avatar
Registered User
Do you have a normal flush system installed? Like a male garden hose bib with a lever to switch motors. I don't have pickups on my drives so that's how I run mine
32hustlin is offline
Old 01-29-2014 | 07:01 PM
where is that lever??
way2fast is offline
Old 01-29-2014 | 07:08 PM
32hustlin's Avatar
Registered User
My setup is on the firewall, could be anywhere in the bilge though. Pics would help
Old 10-27-2014 | 11:49 PM
I was sure the pickups those two scoops at the very bottom of the transom? common on nearly all old cigs?
way2fast is offline
