Pro charger
Old 01-28-2014 | 12:20 PM
Default Pro charger
HI guys,
I want to upgrade my 502mpi with a pro charger . Do I need a ECU reprogram ? Injectors upgrade ? Hi pressure fuel pump ?
What do i need to upgrade for the pro charger ?
Also if someone has a used 502Mpi pro charge for sale let me know please
Bulitz is offline
Old 01-28-2014 | 12:36 PM
You need a checkbook with a lot of $$$ in the account and and engine builder that knows what he is doing.
Griff is offline
Old 01-28-2014 | 12:59 PM
Why ?
Bulitz is offline
Old 01-28-2014 | 01:27 PM
GPM
Originally Posted by Bulitz
HI guys,
Do I need a ECU reprogram ? Yes, Injectors upgrade ? probably, High pressure fuel pump ? probably new fuel system that can supply enough fuel for the added HP. What do i need to upgrade for the pro charger ? Depends on how much HP you're planning to add. Possibly: Fuel system, exhaust system, head gaskets, inconel exhaust valves, outdrive.
GPM is offline
Old 01-28-2014 | 02:09 PM
An extra 100hp was planning
Bulitz is offline
Old 01-28-2014 | 02:18 PM
Yes new fuel pump, fuel regulator, ECM reprogram, may be able to get by with factory injectors, depending on the boat cutting things to make it fit.
baditude is offline
Old 01-28-2014 | 02:41 PM
t500hps's Avatar
21 and 42 footers
HI guys,
Yes, Yes, Yes
Do not listen to someone who says they can "tune" your computer without having the motor. If you really want it to live you need to have the ECU programmed as built on a dyno (or at least while running on the water). If you have more than 200 hours on the motor I'd recommend a re-fresh/re-build depending on it's condition.....since it's a 502 it's likely 10+ years old and if un-opened since new your asking for trouble IMO.
t500hps is offline
Old 01-28-2014 | 03:27 PM
Default supercharger
Originally Posted by t500hps
Yes, Yes, Yes
vortech makes a complete kit to achieve 570hp. it comes with pre-programed ecu and map sensor. no modifications to fuel system. I think the kit comes with an extra electric fuel pump and
a fuel pressure optimizer. I think the kit is north of 5,000. To bad I just sold a good used one for 2000. If you have a late model 502 with mefi3 ecu and serpentine belts, it is a pretty bolt and go system. If you want to email me I can send you the install manual. it works great for what it is
larry
ldillow is offline
Old 01-28-2014 | 03:51 PM
Quinlan's Avatar
Drive
Quinlan is online now
Old 01-28-2014 | 03:56 PM
where do u want to drive to?
ldillow is offline
