1999 Eliminator with Arneson drive minus power and short Blocks >
Old 01-28-2014 | 04:14 PM
Default 1999 Eliminator with Arneson drive minus power and short Blocks
1999 Eliminator 250 Daytona cat with arneson drive minus power. Have photos listed on offshoreonly ad, with describtion.
Dart Big M block short deck with eagle crank and rods SRP pistons flat top, Hydralic roller cam and lifters, fluid dapner, adjustable timing chain and gear set 530 cu inch 4.600 bore 4.00 stroke .250 longer rod .Fresh 4,000.00 firm
Mark 4 big block short deck short block .70 over probe forged pistons small dome 9.5 to 1 with 118 cc head , 7/16 rods, steel crank, bearings, rings, fresh 2000.00 firm
Call with any questions
585-978-0391
chefke is offline
Old 01-28-2014 | 05:29 PM
If you are trying to sell something and you too lazy to to post up some picks on here , at least post a link to your add.
Blueabyss is offline
Old 01-28-2014 | 06:05 PM
So a 25 eliminator and arnesons for 4k? 16000 off? http://www.offshoreonly.com/classifi...o55496-en.html
HEDGEHOGER is offline
Old 01-28-2014 | 06:16 PM
I think someone forgot a "0" in their price..cause just the drive is worth more then 2g..
stlliberator is offline
Old 01-28-2014 | 06:39 PM
The engines are $2,000 and $4,000 respectively
Unlimited jd is offline
Old 01-28-2014 | 07:20 PM
Ad lists 20k for boat.. And 2k and 4k for the engines described?
nailit is offline
Old 01-28-2014 | 07:43 PM
Thanks lil red sorry for the confusion,
chefke is offline
