Chevy / Merlin big block - Best / best capacity block mounted water pump , >
Old 01-30-2014 | 12:04 PM
Default Chevy / Merlin big block - Best / best capacity block mounted water pump ,
Thinking about going "half" closed loop cooling 50/50 antifreeze/deionized water), to limit sea water corrosion on my 722cu chevy merlin motors.
Anyone got a recommendation for a high capacity block mounted water pump for the closed loop side of things.
Is electric (CSR) better or worse than belt drive, any help much appreciated.
Also any recommendation for heat exchangers.
bernie is offline
