Dual Ram Hydraulic Steering
Installing dual ram external steering on my boat. When running lines from the port side ram to the starboard side ram, inside the boat! how are you running your lines? Under the inner transom plate or over the inner transom plate? Pics wouldbe great.
It generally depends on the set up. I have done several installs and always ran them across the top. I try to keep as many holes as I can above the water line. When you run them across the top get them up as high as possible and you wont see them when the hatch is opened. Makes for a cleaner looking install.
