Alpha to bravo >
Alpha to bravo
Alpha to bravo
Old 02-01-2014 | 01:44 PM
Scarab2323's Avatar
Default Alpha to bravo
I got a 350 mags I'm going to convert to 383 in fall I don't want to waste money on ext steering if I got to go to bravo is it easy to convert over and what parts can I use on the alpha if any any help would be great
Scarab2323 is offline
Old 02-01-2014 | 06:10 PM
t500hps's Avatar
21 and 42 footers
You can re-use the engine.......and maybe the prop if it's currently too large. Transom assembly, etc will not be re-used. I once heard the inner transom plate could be re-used but not sure. And, if the boat will hit 70 mph you REALLY need hydraulic steering regardless which drive you are running.
t500hps is offline
Old 02-02-2014 | 01:07 AM
You need complete transom assemblies and the drives of course. You will need to drill 2 more holes in the transom for the Bravo transom assemblies to bolt up.
Griff is offline
Old 02-02-2014 | 07:10 AM
You will also need raw water pumps to get water to the engines from through the drives or through the hull. Bravos dont have water pumps as Alphas do
sprink58 is offline
Old 02-02-2014 | 07:48 AM
If it was me, I would stay with the Alphas. I long term boating friend has a mid-80's 30' Scarab with SBC 383 rebuilds making mid-300's HP and he has never broken a drive. Even if you broke a drive, you could fix it for a fraction on the Bravo conversion process.
BenPerfected is offline
Old 02-02-2014 | 08:23 AM
I know how u feel. I just put in a 500 hp sbc in my 24ft boat with a alpha 1. It scares me but I can't afford the bravo this yr so I have been looking for anything I can to help the alpha live threw this yr. benperfected has a good point! With 2 drives its not as hard on them. So yes u have to drill two holes per out drive and add water pumps. Plus if u have power steering coolers they may be the wrong size hose and u will have to adapt. U will need inner and outer transom assembly's as mentioned above. Plus two new flywheel covers(I think?). Two drive couplers to work with the bravo drives and of course the drives. If u were looking for opinions and I know u did not ask but I would put showers and lube reservoirs on the alphas and run them till u blow one up. With twins u can still make it back to the ramp!!
So2fast5u is offline
Old 02-02-2014 | 08:45 AM
Scarab2323's Avatar
Thanks all I think I'll run the alphas with drive showers and see what happen with the more power behind the drive and get ext.steering I'll keep you all posted if the drive make it or not...
Old 02-02-2014 | 11:12 AM
vintage chromoly's Avatar
I'd run the alpha drives too. Keep the gear lube fresh and use good lube and don't be "mr. Holeshot" and they will do ok.
vintage chromoly is offline
Old 02-02-2014 | 05:24 PM
I'm doing this conversion now just for piece of mind. I was running an SEI Alpha behind my BBC w/500 hp + with no issues but was able to buy a complete boat to get all parts needed to convert.
As mentioned you will need a raw water pump setup, drive reservoir, intermediate housing, gimbal assy, and possibly may want to change the coupler.
I will post pics soon of the swap.
Fast N Loud is offline
Old 02-02-2014 | 07:02 PM
My 383 that I'm building should be 440 ish hp & Tq. I'm staying with the Alpha, just keep it cool, good lube and don't beat on it out of the hole and it should live a decent life.
CC230 is offline
