Best tool to cut out new transom wood?
I am in the middle of a transom/stringer replacement build, and was curious which type of cutting tool is best to cut out the new 3/4 marine plywood? I'm guessing a router type of a tool, but wanted to confirm and get a recommendation on the best bit if this happens to be the best tool to utilize. Thanks in advance!
i like a circular saw. measure in sections, cut out the sections in card board... make sure its perfect. then cut out the wood.. you can use a large angle grinder to make minor sanding adjustments as well...
You do want to cut a bit larger then epoxy all edges and holes, re-drill holes to proper size after epoxy.
Cut a lot of transoms with a circular saw in your 19 years? Just curious.
It's guys like glassdave and a couple others who make this section very helpful. Then there's the majority of guys who are hell bent on insulting folks for asking questions. Here's some advice, egos eat brains... The young guy who posted above may not have all the experience, but he is courteous enough to help with the information he currently had available. And as any intelligent man knows, you take several opinions and then formulate your plan. I'm here to learn in the area of fiberglass and specifically "Glassdave" had been a very helpful professional. I can't thank him enough. Nothing but class there. However, quite a few of you need to remember basic manners. I'm also not afraid of a literary throw down, if warranted. You want this sport to grow, but yet you do nothing to promote that growth.
I cut two of them. found the easiest was the jig saw. What made the biggest difference is when I stepped up to the plate and bought a top of the line Bosch saw. Forget the black and decker or bottom end craftsman. I was pissed when I got the new saw knowing all the frustrations I had chasing the blade on the cheep ones. I can just about split a pencil line. Like the others have said, cut on the larger size and you can shape it with a belt sander.
