Lets see your engine hatches!! >
Old 02-03-2014 | 12:03 AM
Default Lets see your engine hatches!!
Im looking for ideas for the engine hatches im going to be building in the spring im hoping to switch from a single hatch to two side flip hatches with scopes lets see what everybody has
HEDGEHOGER is offline
Old 02-03-2014 | 12:39 AM
Randy Nielsen's Avatar
Are you "wanting" to build your own or would you buy some if they fit your needs? Randy
Randy Nielsen is offline
Old 02-03-2014 | 09:08 AM
Looking to Building them for a final project In my composites class
Old 02-03-2014 | 09:43 AM
Old 02-03-2014 | 09:52 AM
Tom A.'s Avatar
Here are a few of my Donzi and one of my old Kryptonite
Attached Thumbnails Lets see your engine hatches!!-nyc-11.jpg   Lets see your engine hatches!!-p5240262.jpg   Lets see your engine hatches!!-tampa-spring-2013.jpg
Tom A. is offline
Old 02-03-2014 | 10:12 AM
Tom do you have a center bar or they just fit together 1 first the the other ?
Old 02-03-2014 | 11:10 AM
TeamSaris's Avatar
Driver-441
Racer
[ATTACH=CONFIG]517798[/ATTACH][ATTACH=CONFIG]517799[/ATTACH][ATTACH=CONFIG]517800[/ATTACH][ATTACH=CONFIG]517801[/ATTACH][ATTACH=CONFIG]517802[/ATTACH]We did the opposite. Had Two side by side aluminium ones on the Cobra...bolted em together, used it as a mold and made one big one. Much lighter, less hassle.
Attached Thumbnails Lets see your engine hatches!!-hatch2.jpg   Lets see your engine hatches!!-saris441-1-.jpg   Lets see your engine hatches!!-_mg_0405.oc.jpg
Lets see your engine hatches!!-251273_475761245780685_2009330974_n.jpg   Lets see your engine hatches!!-1610104_10202372556428304_623806764_n.jpg
TeamSaris is offline
Old 02-03-2014 | 12:15 PM
Tom A.'s Avatar
It is actually just one hatch.
Tom A. is offline
Old 02-03-2014 | 12:53 PM
Here are a couple pics of the one I built for my boat
Attached Thumbnails Lets see your engine hatches!!-2013-02-16_11-55-12_111.jpg   Lets see your engine hatches!!-img_1795.jpg
sonic700 is offline
Old 02-03-2014 | 12:54 PM
I did my hatch on the budget using 7 ply marine plywood ,painting it with PPG. Single hatch though. Boat used to have superchargers before so built the hatch with scoops in case I go back to superchargers. Now just two N/A Mercs under the hatch. The scoops sure help keeping under hatch temperatures down.
Ps; What I did with the two lifting rings you see on the hatch, when I raise the hatch to maximum I can pull the pin and switch ram to the rear that allows the hatch to go straight up for maximum access to grease couplings and do other service etc.....
spectras only is offline
