242 Islander 6.2ltr  re powering questions. >
Old 02-05-2014 | 02:21 PM
Default 242 Islander 6.2ltr re powering questions.
I have 2004, 242 Baja Islander 6.2ltre 320hp,Bravo one 3x19pitch. Re powering 4th time always same thing loss of compression. Anyway I have two questions. 1 does anyone know if this 6.2 engine a known problem child of mercruiser or not?
2 My mechanic is selling me 454MagMPI engine out of another boat. We are having it sent to the machine shop and to be freshened up. I am getting itch for more HP and speed out of the boat. So my mechanic suggested we put a HP500 cam in the block and run a carb, He said the EFI cant be messed with to develop more power etc. I want to know is this a good set up? Has anyone done this before and what might i see for power out of this set up? Also how much power is to much power for my 242? Any advice be great thanks again
04Baja242islandr is offline
Old 02-05-2014 | 03:24 PM
If you put a set of 502 heads on it and a roller cam you can pull 385HP. Don't know what the HP500 cam will give you, may be a good cam but will not give you the same HP. Merc made many 385HP horizons motors, just pulled one out last year. one of these days may get around to rebuilding it
AllDodge is offline
Old 02-05-2014 | 07:05 PM
Loss of compression is extremely vague. What exactly happened mechanically to cause the loss? I saw you have been through a number of them each with the same problem. Definitely need a new mechanic. Where are you? I'd ask someone for recommendations here.
I lost two 6.2s to a really strange problem. My raw water fuel cooler fitting had corroded and was letting in minerals, which then the fuel pump shot up to the injectors clogging them and caused the engines to lean out then boom...new engines. If my mechanic wasn't paying attention, I could have easily reinstalled two new engines and blown them from the same problem. I am certain not many mechanics would have found this one.
Captain YARRR is offline
Old 02-05-2014 | 07:16 PM
I'm in the Tampa area, all engines around 100hrs end up with rusty plugs and loss of compression
Old 02-05-2014 | 07:24 PM
454 mag mpi makes 385 hp out of the box.
Hp500 cam and carb will make more but you will need an exhaust upgrade too.
Also, you absolutely can make more HP with efi. You can have the computer flashed, injectors and throttle body can be upgraded, intakes can be ported, high flow air filters.
Baja226sport is offline
Old 02-05-2014 | 07:32 PM
Are you using old exhaust On the 6.2's?
You should see about 450hp with hp500 cam, 800 holley, single plane intake, roller rockers, and aftermarket exhaust. Definitely not to much power for the boat.
Old 02-05-2014 | 07:58 PM
Using the exhaust that magmpi came with 6.2 exhaust won't fit on big block
Old 02-05-2014 | 07:59 PM
Can't afford new bb custom exhaust at this time so going with factory mercruizer manifolds and cast ss riser the magmpi came with for now
Old 02-05-2014 | 08:07 PM
That doesn't really clear anything up. Did you blow a hole in a piston? Did you lose a valve? There's a lot of different things that cause loss of compression.
Old 02-05-2014 | 08:27 PM
Engines heads have not been pulled so he does not know niether do I. Engine is not being rebuilt because I told mechanic don't waisted my money for a year down just remove it and I want a different engine with more power since this is the 4th go round. Il have the engine on a pallet and on craigslist soon for whatever I can get for it
