502 mpi mag EFI complete set up >
Old 02-11-2014 | 05:05 PM
Default 502 mpi mag EFI complete set up
I'm sailing my complete kit off my 502 mpi mag!
Intake top and bottom
Flame arrester
Upper and lower wiring harness
Injectors
All ignition
Computer
Dist. And coil
Bolts
And the EFI cam that came out of this motor!
And all fuel set up
Should be all you need to swap to this EFI set up or add! all in good shape, I pulled it off and will be going to a carb set up
1,500 also not sure if it's priced right just went off what I've found so make reasonable offer
281 six nine one 5807
Pic to come
Mike S. is offline
Old 02-13-2014 | 11:06 AM
Mike S. is offline
Old 02-13-2014 | 11:51 AM
What year?
Pismo10 is offline
Old 02-13-2014 | 12:50 PM
Mike S. is offline
Old 02-15-2014 | 11:25 AM
Want this out of the way 1,300 for all that's a deal, some one needs it!
Mike S. is offline
Old 02-15-2014 | 06:41 PM
What's the lower intake look like? Any corrosion?
jvcobra is offline
Old 02-15-2014 | 06:46 PM
Double post sorry
Mike S. is offline
Old 02-15-2014 | 06:48 PM
Edit: just clean and looked at it, Always been a fresh water motor, little corrosion not much and it has a small spot that looks like it's been bronzed on the front water runners very good job! nice and clean, ill take pic for you but I can't post them tell Monday at the office!
Mike S. is offline
Old 02-17-2014 | 07:51 PM
Bottom of intake never had water in the motor no leaks, Im just building a new motor and going carb I've never been big on EFI so going back with something I know! Carb! Lol
Mike S. is offline
Old 02-18-2014 | 01:56 PM
I've had quite a few offers on splitting this unit up wasn't going to but there's more interest maybe in pieces so! Here's what I can do or you can make a offer, I would really like to sale the intake first but will see what's offered!
Intake upper and lower w/TB & flame arrestor- $800
Lower wiring - $150
Upper wiring - $150
Cam none roller-$100
Computer w/ brackets and box MEFI II- $300
Fuel sys. With injectors and fuel rail - $150
Mike S. is offline
