LED Lighting Suppliers
Old 02-11-2014 | 08:07 PM
Default LED Lighting Suppliers
I recently went through a large RFP at work for interior lighting and learned that some high priced LED's can be junk, and some low price led's can be great and its difficult to tell.
Im looking water proof white bilge lights, colored strips for the gun wales, white courtesy lights for the interior and maybe under water lights. Any recommendations?
thanks
stimleck is offline
Old 02-11-2014 | 08:34 PM
www.lizardleds.com
I recently bought two boat kits and have been pleased with the results.
I will post some pics of them soon.
Fast N Loud is offline
Old 02-11-2014 | 09:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Bought all my interior LED bulbs from Marinebeam. Somewhat pricey, but worth it IMO.
I look for the wide voltage, ex 10-30v, range specs, vs just the 12v rating.
http://store.marinebeam.com/technicalinfo.html
I did buy a roll of waterproof LED thru ebay for $15. So far it has been just fine.
US1 Fountain is offline
Old 02-12-2014 | 03:22 PM
I also have had very good success with ebay lighting. You will find something that will fit your need and at good price.
If you want to kick it up a notch try Varad (info at http://www.varad.com/v4/) undercar lights that are multifunctional and you can actual make your lights go with the music. I have 2 sets on my boat. One set I have mounted under the transom for 3 years and they work great.
inxsinxs is offline
Old 02-12-2014 | 04:12 PM
VoodooRob's Avatar
I too bought the $20 LED roll off eBay and use it in my engine compartment. Mounted it with 3M emblem tape, the tape supplied was junk off the get go. The lighting is holding up, no issues. [ATTACH=CONFIG]518498[/ATTACH]
VoodooRob is offline
Old 02-12-2014 | 04:28 PM
superbrightleds.com the only place I by LED lights from. They have some really nice waterproof stuff. Very cost effective as well.
low_psi is offline
Old 02-12-2014 | 06:45 PM
What do people use to stick to fiberglass? I used a thick Velcro strip on the fiberglass gun wales of my engine compartment. After about a month, it started falling off.
242LS is offline
Old 02-12-2014 | 07:19 PM
Default these are like the lizard
16 foot roll rgb with remote and control 30 bucks on ebay IP 65 rated and I stuffed them into a half inch insert rub rail
Attached Thumbnails LED Lighting Suppliers-025.jpg   LED Lighting Suppliers-026.jpg   LED Lighting Suppliers-028.jpg
lightning jet is offline
Old 02-12-2014 | 10:40 PM
VoodooRob's Avatar
Auto zone or Pep Boys, 3M emblem tape ( gray tape with red film on adhesive side )
Old 02-12-2014 | 10:59 PM
Ginger or Mary Ann?
Picked up the double sided tape at Menards paint dept. Not sure if it is 3m or not, but has the red peel off covering. It's more of a thick rubber tape than the thin scotch type tape that is usually supplied with the ebay lites. I have a strip under my swim platform and it gets soaked, 2 yrs and still stuck like the day it was installed.
