2001 F-150 super-crew w/ 5.4 ???? >
Old 08-13-2002 | 11:49 AM
Chris288's Avatar
Default 2001 F-150 super-crew w/ 5.4 ????
truck comes with factory Tow-package, am I assuming correctly that it includes a tranny cooler.
Chris288 is offline
Old 08-13-2002 | 12:04 PM
big daddy's Avatar
You are correct.
big daddy is offline
Old 08-13-2002 | 12:11 PM
Chris288's Avatar
Default Thanks,,, Daddy...
I saw an aux. cooler and assumed it was the tranny, but figured it could have been engine oil also. Its pretty small..
Chris288 is offline
Old 08-13-2002 | 12:38 PM
Iggy's Avatar
Look again.
I thought the same thing, it's the power steering fluid cooler.
Unless they changed things since mine was built (1997) the oil cooler (oil to water) is engine mounted with the oil filter located in front of the left front wheel and the trans cooler is in the radiator. Follow the lines from trans and see where they go.
1997 F-250 Lariat S/C 4X4, short bed
5.4L, E4OD trans and 3.73:1 gears
Iggy is offline
cherrycobalt262
11
03-09-2006 08:48 PM
Chris288
5
01-19-2005 02:58 PM
Chris288
02-17-2004 09:55 PM
