Removing fuel rail/injectors on 496 MAG
Thinking at 10 years and 400 hours it might be a good idea to send my injectors off for a cleaning and flow testing. Would also give me an opportunity to check the conditon of the inside of the fuel rail. I've done a bit of searching but came up empty handed on do's/dont's of removing the rail and the injectors. I don't have access to the boat at this time, so I have to go off memory here. Do I need a tool to remove the fuel line that feeds the rail? Is there a return line as well? Unhook the harness from the injectors, pull the rail off the injectors in one piece? Pull clips that hold injectors in place and pull out injectors? Looking for input from those that have done this before. TIA!
all you need is a quick fuel line disconnect tool (if you dont have one you could get one at sears),disconnect the harness,remove the 4 rail retaining bolts and gently pull up, make sure the lower injector orings came out with the injectors and did not get stuck in the plenum,done.
It most likely is the same tool. If not they are about $8.00 at any auto parts store. I have had my intake off on my 496, and that was the only special tool needed, aside from a torx bit to remove the cover.
