Burned rubber on Stainless riser... >
Old 02-17-2014 | 01:22 PM
Default Burned rubber on Stainless riser...
Can anyone suggest ways of getting burned or melted rubber off a stainless riser?
chrisf695 is offline
Old 02-17-2014 | 05:19 PM
ChrisF695
If the "rubber" is just on stainless and there is NO coating on the stainless you could try Acetone -- You can buy this at Lowes or any home store
You need to be VERY careful- Acetone is very flammable and it evaporates in a flash -- You need to make sure that your pipes are stone cold -- it will take a while but acetone is a excellent solvent and will not leave a residue. Also if you smoke DON'T do it anywhere near the solvent.
Also be VERY careful not to spill ANY on carpet, rubber, electrical stuffs - It will dissolve most "organics"
hope this helps
3pointstar
3pointstar is offline
Old 02-17-2014 | 08:07 PM
Originally Posted by 3pointstar
ChrisF695
hope this helps
3pointstar
Thats awsome, thanks for the suggestion!
