Engine and Sterndrive Serial check >
Old 02-18-2014 | 11:54 AM
Default Engine and Sterndrive Serial check
Hey guys,
I know a few of you out there are great at running serial numbers. I'm looking to confirm my setup (just got the boat in the fall, haven't tore too far into it yet).
Engine - 0K026165 - it's a 5.7L 2bbl, but I'm mostly interested in seeing if it's flat or roller lifters (looks like the valve covers used on roller motors, but that's not always a reliable way to tell).
Sterndrive - 0K266272 - Transom - 0K125577 - Here I'm trying to figure out my drive ratio...looks like 1.62, but I'm not sure.
Propeller - 48-832832C121 - Looks like a 21p, but I'm not sure of the diameter (whole boat is shrink-wrapped right now)
Any info on these numbers is much appreciated!
jstand22 is offline
Old 02-18-2014 | 11:51 PM
According to serial number its manufacture date is 07/29/96. By putting serial number into parts catalog it could be either flat or roller, both have same valve covers.
Drive is gen 2 alpha 1.62 ratio
prop is 14.25 diameter x 21 pitch Blackmax aluminum. Should be in 1997 18 foot Baja from VT
Sorry cant help with lifter question youll have to look and see
jray1010 is offline
