JR Marine swivel pin & U Bolt HP transom assembly
I'm buying a new HP transom assembly and curious if the JR MARINE stainless swivel pin & u bolt fit this transom assembly. The reason I ask is that the gimbal ring is thicker than the standard bravo, just not sure if this means also where the U bolt goes, meaning it won't fit... I tried calling, but Ron is gone until next month. Thx
Awesome thank you!
I realize its "new" however it still has the mild steel pin which rusts and wipes out the swivel pin seal and starts to wear the ring... The U bolt is also a weak point. If I can change those two parts before installing, it will buy me time as I'm not going to run external steering until next year. This project is already way outside of original budget.
