AIr Gap RPM or Performer for procharged 454 with Edlebrock oval marine heads? >
Old 02-21-2014 | 12:51 PM
Default AIr Gap RPM or Performer for procharged 454 with Edlebrock oval marine heads?
I have a 454 with Stock cam and exhaust, procharger blow through carb and after cooler, 9.5/1 compression, Edlebrock Marine oval heads Want to run pump gas and keep bravo drives.
Should I go with the Edlebrock 2161 performer or 7561 air gap Intake manifold?
Thinking the air gap will keep it cooler or should I just block the exhaust crossover on the Performer?
Should I run a thermostat or not?
schurgervt is offline
Old 02-21-2014 | 01:10 PM
Since you're running FI your intake temps are gonna be higher, Probably no noticable difference between the two, or blocking the crossover. For the thermostat I'd say yes since you boat in colder water, it'll keep you motor temps consistant.
fastdonzi is offline
Old 02-21-2014 | 01:25 PM
GPM
Air Gap, how much boost are you planning to run ?
GPM is offline
Old 02-21-2014 | 07:12 PM
About 7 psi
Old 02-21-2014 | 07:32 PM
GPM
I think cooler would be better for less detonation,
GPM is offline
proformer intake .no stat
happy is offline
Old 02-21-2014 | 07:37 PM
Edelbrock performer rpm air gap .with thermostat
motor is offline
Old 02-21-2014 | 10:36 PM
hp 500 intake or a victor jr..you will end up with turbulence with a air gap.. the dart and edlbrock victor jr is a straight shot and thats what you want with boost..you want the boost to get to each cylinder as even as possible..
FIXX is offline
Old 02-22-2014 | 05:31 AM
Now that i'm up and have no drink in my hand ,I re-read the post .I didn't see it was boosted. I agree with fix..
motor is offline
Old 02-22-2014 | 08:31 AM
If you're budget is tight, this one would work. I'd also watch that 7psi boost level with 9.5:1 Compression. Especially if you have a small cam. An IAT gauge after the intercooler would be a good idea.
http://www.competitionproducts.com/P.../#.UwizwoWSyZE
MILD THUNDER is offline
