Bravo x gears
When the XR drives came out they redesigned the helical gears as well. They made the foors thicker and designed them to beable to fit the older drives. Since then the broken floor problem is not an issue. The next weak link is the tower itself. The teeth on the gears are the same for the helical gears, just the floor is thicker.
Hope that helps..
Dick
Hope that helps..
Dick
