Can anyone answer my boatin buddies ?
Ron seems to believe his spline/ drive shaft coupler between the engine and the outdrive has stripped out. It should be confirmed in the next day or two. Are you aware of a "High Performance" coupler that is stronger and more durable than the stock one? Let us know as he would like to replace it with something a little stronger if possible. He has about 130 hours on the drive train and this seems like an odd occurrence. No prop damage etc....
He bought a new Donzi 27 w/385 hp
If he wore it out in that many hours behind stock power, I'd be looking at drive alignment as a cause. Even straight from the dealer I would check a new boat. Peace of mind. What year is the boat?? Regular service (grease the zerk fittings, etc...)?? Does he ski with it?? Pull wake boards?? Live for the hole shot?? All these things can lead to less life from a coupler. Myself, I got over 400 hours out of mine before I replaced it this season, and I replaced it only because it was starting to look worn, not because it didn't work anymore. Again, peace of mind. And I didn't want to have to pull the motor (again!!) to replace it if and when it failed.
What are the symptoms?? Revs up but goes no where fast?? Rubber hub prop? Even without visible damage the prop hub could be bad.
I just replaced mine on a 98 260 Powerquest with 200 hrs. The front 2 nuts on the motor mounts were loose. If the motor is out of alignment it will cause premature wear. I replaced it with the standard coupler. They do make a heavy duty coupler thats steel instead of aluminum. My mechanic didn't want to put it in with a stock motor. His feeling was, better to strip the coupler than break the drive. The coupler cost me 700 bucks installed vs big $$$ for outdrive repair. Does the boat not go in gear? When mine stripped out the coupler was turning but the shaft on the drive wasn't. So I was stuck! 400 bucks for seatow
Good luck!
Good luck!
When my coupler went I was dead in the water too. You can see the coupler spinning but not the shaft and there were metal shavings in the area. My cause was the front motor mounts coming loose too. Fortunatly mine was under warranty.
I blew the splines out in one last year, not long after get the boat. Engine alignement was perfect. No holeshots possible due to blow out of the prop if tried. My case was definately due to no grease on the zerk by previous owner. Boat had about 375 hours on iit. My other boat had 1000hrs on original coupler with me maintaining it over the years. Grease is the key to spline life.
BT
BT
I've more of a question than an answer. The other responses all advise greasing the zerks on the spline. What type grease do you use? I need to grease mine now, and wonder if I just buy the Mercruiser grease or is there a preferred alternative?
I've got a 454 Mag with a Bravo I outdrive.
