2014 Rubber Ducky RD410 Inflatable Race Cat (13.5ft)
New 410 Race Boat - Bright Yellow - New, just inflated at my shop..
Figure with a 40hp and two people 45mph plus - if your looking to have the fastest toy in the marina look no more!!
All boats are hand glued; They are much more durable than those be made by machines. Each seam is overlapped by one inch and reinforced with seam tape both outside and inside for extra protect-ability.
To maximize adhesive strength, we use Ployurethane glue that guarantees high durability and protection from heat and sea water.the accessories match the boats well.
FLOOR CONSTRUCTION - The floor is constructed of light weight yet strong aluminum alloy, not a cheap fiber board or heavy marine plywood that will eventually get water logged. 410 Race model has three floor boards joined by an aluminum strip. If the boat is deflated then these can be removed. Depending on the rigging of the boat, it is possible to roll the boat for storage and easy transport.
The wash through (open) transom in the base model is designed so that the boat will release any water it might take on in some severe sea conditions. An optional closed transom with scuppers will be available soon.
TUBE CONSTRUCTION - The multi-chamber tubes in the base models are manufactured with high quality 0.9mm PVC, 1.2mm PVC, 0.6mm HYPALON, 0.7mm HYPALON, 0.9mm HYPALON.
DIMENSIONS 410 RACE
Length 13'.5"
Beam 6'.5"
Inside length 7'.8"
Inside width 2'.8"
Tube Diameter 1".7'
CAPACITY
Maximum passengers 5
Maximum passengers + Load 1200lbs
Dry Weight 155lbs
Airtight chambers 6
OUTBOARD DATA
Shaft length recommended (Short 15")
Minimum engine H.P. 30hp
Maximum engine H.P. 70hp
Recommended engine size 50hp
Maximum engine weight 130lbs
Maximum operating speeds 50mph
Steering Tiller
TUBE PRESSURE
Recommended tube pressure 7psi
Recommended Hi-Jacker pressure 13psi
STANDARD EQUIPMENT
Foot / Hand straps 5
Carry handles 4
Inside storage bags (large) 2
Inside storage bags (small) 2
Repair (patch kit) Yes
Paddle kit (oars) Yes
Hi flow foot pump Yes
Race (MC) number windows Yes
Back Cushions Yes
Oversized grab rope Yes
Tow Line Yes
$3,499.00
Call (FIVE EIGHT SIX) 2 SIX 0 - 9 FIVE 1 EIGHT with any questions. Thanks Rk
DIMENSIONS 410 RACE
Length 13'.5"
Beam 6'.5"
Inside length 7'.8"
Inside width 2'.8"
Tube Diameter 1".7'
CAPACITY
Dry Weight 155lbs
Airtight chambers 6
OUTBOARD DATA
Steering Tiller
TUBE PRESSURE
STANDARD EQUIPMENT
Carry handles 4
Back Cushions Yes
Tow Line Yes
$3,499.00
