Prop Change?? >
Prop Change??
Prop Change??
Old 02-27-2014 | 06:57 PM
Default Prop Change??
Currently have 3blade 23 pitch on 30 scarab with 350 mags. looking to change to 4 blades... Thoughts/ input..
msher44 is offline
Old 02-27-2014 | 07:11 PM
What RPM are you seeing with the 23 3 blades? Are they mirage, or Mirage plus?
If you need a tad more RPM at WOT, i'd try a 21p Revolution 4 blade. If you're rpms are good, or maybe need a tad less, I'd try a 23p Revolution 4 blade.
MILD THUNDER is offline
Old 02-27-2014 | 08:47 PM
About 5200. They are lasers..
msher44 is offline
Old 03-03-2014 | 07:11 AM
I think you would be happy with a switch to Mirage plus 3 blade props
The Laser props are designed for small light boats and are likely to have high slip numbers on a large heavy boat.
flyinlow is offline
Old 03-03-2014 | 01:28 PM
Sounds right. Thanks.
msher44 is offline
