Go Back  Offshoreonly.com > General Discussion > Offshoreonly Industry News
Comparing The MTI V42 and 52′ Pass Blocker Catamaran >
Old 03-03-2014 | 04:12 PM
KennyOffShore's Avatar
Administrators
Default Comparing The MTI V42 and 52′ Pass Blocker Catamaran
There is nothing—and I mean zero—wrong with being among the last boats to arrive at the lunch stop of a poker run. That’s especially true if your ride was a pleasure, and that’s a fair description of the last hour I spent on Greg and Brenda McCauley’s V 42 center console from Marine Technology Inc. Between a stiff crosswind and a sloppy mix of go-fast boat and cruiser wakes, conditions were anything but smooth. They also were anything but challenging for the 42-footer, which has an 11’6″ beam and rides on a patented stepped hull.
While we nicked 70 mph a few times thanks to four 300-hp Mercury Verado outboard engines on the transom, we spent most of our time cruising at a comfortable 60 mph and—as we approached the mangroves leading into Key Largo and our lunch destination at Gilbert’s—50 mph. Truth be told, in a boat with the kind of heft of the V 42, the difference in sensation between 50 and 70 mph is mostly experienced through the onrushing wind. The ride doesn’t change a whole lot.
Next up, I’m on board the 52-foot MTI cat called Pass Blocker with owner Brad Benson, Tom Healey and the rest of their crew. Given that the boat is canopied, there should be a whole lot less breeze to deal with. But given that it’s reportedly capable of 185 mph—not to be done in the poker run, of course, which has a 150-mph speed limit—it should be every bit as fun as the 42-footer. Maybe even more. Stay tuned.
KennyOffShore is offline
HTML code is On
