Y- Pipe CAPS
Y-Pipe Insert Caps $60
These caps are used when switching to a thru-hull exhaust system or when removing silent choice systems when the y-pipe is no longer needed to route the exhaust. Instead of pulling the engine to remove the y-pipe you can now easily slip these in and clamp them down, easy as that. Made of stainless steel these caps will be good for years to come. Sold in a pair.
