do you HAVE to resize the rod big end when you install arp rod bolts? >
Old 03-04-2014 | 11:02 AM
ratman's Avatar
Default do you HAVE to resize the rod big end when you install arp rod bolts?
im building a lil toyota 22r engine for my daily driver, and want to install some arp rods bolts, but dont trust the local machine shop to resize the rod ends. is resizing mandatory/ thx, rm
ratman is offline
Old 03-04-2014 | 11:27 AM
If you are replacing stock type bolts with ARP bolts, then yes, you will need to resize them. The ARP bolts will have a higher clamp load and will certainly cause the rod to be out of round.
Eddie
Young Performance is offline
Old 03-04-2014 | 11:43 AM
ratman's Avatar
thx i thought so... im going to run the oem bolts...rm
ratman is offline
