max rpm on 502?? >
max rpm on 502??
max rpm on 502??
Old 08-14-2002 | 11:44 AM
stevejohns
Default max rpm on 502??
Im trying to get a cam for my mildly modded 502. The bottom end is all stock , what is the max i can turn it to?
Old 08-14-2002 | 12:06 PM
obnoxus's Avatar
Charter Member #1171
I have heard 5500 RPM
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 08-14-2002 | 12:32 PM
ursus
unless its an old Tbolt IV ignition you'l hit the rev limiter ~ 5000/5100
Old 08-14-2002 | 01:18 PM
jdnca1's Avatar
The Issue will be valve train, not bottom end. Bottom will turn 6500 with no problems, I turned a mild 502 mag 6000 in my previous boat. just be sure you have the correct 'combination' of cam, springs, lifters for the rpms you are after.
jdnca1 is offline
Old 08-14-2002 | 01:39 PM
sheikman1
Gen 4 motors with the T-bolt ign. have no rev limiter...The Gen V has a rev limiter.
Just a thought.
Sheikman
Old 08-14-2002 | 02:45 PM
liquid asset's Avatar
I had mine programmed to 5400
liquid asset is offline
Old 08-14-2002 | 04:59 PM
stevejohns
Thanks guys.. according to the guys at nickersons , the roller setup they suggest will run 590 hp at 5600. Looks like i have a winter project.
BY U BOY
18
08-19-2006 02:54 PM
cloudmaster_321
7
06-02-2005 06:03 PM
SOX
2
06-13-2004 07:04 PM
Jonas
19
07-27-2003 11:48 PM
Intolerant1
1
05-09-2002 10:54 PM
