Oil Pressure and Temp senders location on 502 Mag MPI >
Old 03-09-2014 | 10:20 AM
Default Oil Pressure and Temp senders location on 502 Mag MPI
I have 99 Scarab AVS with 502 Mag Mpi and am replacing all the gauges. Gaffrig recomme nded I replace the oil pressure senders. My question is where is this located and also the location of the oil temp sender as may replace those as well. Tried Merc hot line but no help.
sport396 is offline
Old 03-09-2014 | 10:29 AM
c_deezy's Avatar
https://www.google.com/search?q=site...m=122&ie=UTF-8
c_deezy is offline
Old 03-09-2014 | 10:31 AM
Pressure sender is on the back port side of the block, near the traditional oil filter location.
I think the temp sender is on the back starboard side.
Cole2534 is offline
Old 03-09-2014 | 06:16 PM
You really should not need to replace either one of the senders unless they are a totally different style of guage.
Pressure senders is in the block below #7 cylinder.
Oil Temp sender can vary depending on where Scarab put it. There is no factory Merc location.
Griff is offline
Old 03-09-2014 | 06:29 PM
Thanks!!
sport396 is offline
Old 03-09-2014 | 07:19 PM
thats good info griff.
mike tkach is offline
