whats the difference between these two couplers >
Old 03-09-2014 | 03:58 PM
Default whats the difference between these two couplers
one is from the 454 i took out the other is from the 502 im putting in
not sure what changes I need to make to install the 502 now
thanks again in advance[ATTACH=CONFIG]519977[/ATTACH][ATTACH=CONFIG]519978[/ATTACH]
Attached Thumbnails whats the difference between these two couplers-454-connector.jpg   whats the difference between these two couplers-502-connector.jpg
stimleck is offline
Old 03-09-2014 | 04:13 PM
Looks like the 454 is the long snout and the 502 has the std coupler. Same spline nothing to change.
Unlimited jd is offline
Old 03-09-2014 | 06:39 PM
The coupler on the right is an aluminum coupler .The coupler on the left is Mercury's heavy duty coupler made for heavier boats that idle a lot or troll alot.the quality of the hd coupler far exceeds the aluminum coupler.
activator40 is offline
Old 03-09-2014 | 09:58 PM
There are 2 versions of the short coupler, aluminum and steel. I might be wrong, but I don't think the aluminum one is available any longer. The short one is necessary for driveshaft applications.
Falcon is offline
Old 03-09-2014 | 11:51 PM
the one on the left is a gen II alpha coupler ,,,,
this is the heavy duty bravo coupler http://www.bing.com/images/search?q=...lectedIndex=10
the one on the right is just the standard duty big block coupler..
FIXX is offline
Old 03-10-2014 | 12:29 AM
One is a penis the other a vagina. Your mom not teach you about the birds and the bees??
ICDEDPPL is offline
Old 03-10-2014 | 03:37 AM
no she died when i was young a s shole...thanx your comment just brought the worse day of my life...
FIXX is offline
Old 03-10-2014 | 06:06 AM
besides, they are both vaginas. one is just fatter than the other...
dereknkathy is offline
Old 03-10-2014 | 12:37 PM
So I guess ill need ti swap them to install the 502 in my boat with a bravo?
stimleck is offline
Old 03-10-2014 | 02:49 PM
Fixx if I`m referring to you I`ll quote you otherwise I`m replying to the OP. Internet 101 so calm down there buddy
ICDEDPPL is offline
