Parts Blow out!! Cleaning up >
Old 03-11-2014 | 04:32 PM
Default Parts Blow out!! Cleaning up
I am in the middle of a re-rig and have a lot of parts that need to go!! Here is the first list
Call or text for pics, I cant access OSO on phone(forgot log in), so PMs will take longer to answer, 252 three three three 5898
All prices are plus the ride and OBRO, everything worked when it was removed unless otherwise stated, just updating boat
2 MSD Blue boxes with 2 soft touch rev boxes(don't know what chip in them) - $500
1 Gaffrig Offshore Throttles - shift/th/th/shift forward or back cant - w/trim switch - could use paint - $500
1 one set stock cast BBC manifolds with risers w/89hrs fresh water- $125
1 set of gil dry to tip tailpipes, bought and never used, long thru hull version, will work on Bravo or trs - $300
2 of each Gaffrig gauges 2 1/16 volt, oil pre, oil temp, water temp, fuel pre, fuel level, hour meters
2 of each Gaffrig tachs 3 3/8 I believe
1 Graffrig speedo 4" water operated, wasn't hooked up, don't know if it works
$350 for all gauges
15 - 2 1/16 angled purple bezels - 2-3 3/8 angled belzels - 1-4" angled bezel - $150 - If buy w/gauges $115
1 Dual battery enclosure with lid, had to grp24 batteries in it - $30
1 6+/- gal fresh water holding tank - $35
1 biga** halon fire system w/good charge - $35
2 Blower scoops w/mounting plate polished off dual 4150's - $60
1 silent thunder platform off a 94' formula w/rectangle exhaust tips - $100 (Shipping maybe a issue here!!)
2 088 cast heads off a 502mpi with valves and springs, came off running motor w/89hrs fresh water- would freshen before installed - $250
2 thur hull exhaust flanges - $60
1 set of plug wires off 502mpi 89hrs - red - $30
1 set of 8 rocker switches, can add or remove as needed(interlocking) - $30
1 set of 4 rocker switches, can add or remove as needed - $15
1 complete circuit board/switch panel - $50
That's a good start!!!! PLEASE TEXT OR CALL ME FOR QUICK RESPONSE 252 THREE THREE THREE 5898
Im in NC zip is 27944 for shipping
Will have more parts soon posted, blower parts, cams, lifters, etc
Thanks,
Brad
598 Formula is offline
Old 03-11-2014 | 04:50 PM
F-2 Speedy's Avatar
txt sent on the halon system
F-2 Speedy is offline
Old 03-11-2014 | 04:55 PM
Got it, headed home now to get camera and start voguen!!LMAO I will have all pics tonight
Old 03-11-2014 | 06:26 PM
Sick Stinger's Avatar
Brotherhood #1
Blower scoop pics???
Sick Stinger is offline
Old 03-11-2014 | 06:48 PM
Bump, about time, let's get a move on. Lol
Cobra100+ is offline
Old 03-12-2014 | 06:19 AM
buckknekkid's Avatar
circuit pic???
buckknekkid is offline
Old 03-12-2014 | 05:35 PM
Originally Posted by buckknekkid
circuit pic???
Text me
Old 03-12-2014 | 05:36 PM
Text me
Old 03-17-2014 | 03:10 PM
gauge pics to 918-639-0437
Greg
Gh700xx is offline
Old 04-18-2014 | 09:40 AM
Lets go son, get to work! Put some pics up here so this stuff will move. Great deals here
