How do you get keepers to release >
Old 03-12-2014 | 08:30 PM
Default How do you get keepers to release
I am applying 300 or so psi with the vavle spring compressor. They wont release. Are they stuck or something?
mcprodesign is offline
Old 03-12-2014 | 08:55 PM
Bump the top of the spring retainer with a hard rubber or plastic mallet with some pressure on the spring
Mr Maine is offline
Old 03-12-2014 | 09:02 PM
A magnet and a screw driver, just pop em off
ICDEDPPL is offline
Old 03-12-2014 | 09:16 PM
The locks are tapered with steep angle to keep them locked good on the the valve stem so, you'll need an adapter screwed into the spark plug thread and attach the compressor to keep the valve closed while using an appropriate size socket, rap on the valve lock retainer with a metal hammer to break the tension. After that just push down on the retainer/spring ,using a magnet will pull the locks out. It's also advisable to bring the piston up once the locks released in case the valve stem loose/worn in the guide so the valve wouldn't drop in.
spectras only is offline
Old 03-12-2014 | 09:35 PM
Are you sure you are compressing the spring far enough?
MILD THUNDER is offline
Old 03-12-2014 | 10:56 PM
Thanks!! I just hit the facker with a hammer, we're all good now. Looks like the exhaust springs are a little tired, but the intakes are really close to the new springs in mercury boxes I found on ebay. I may have to use these intake springs on my other motor's exhaust valves
Old 03-12-2014 | 11:05 PM
Listen here meatball. lol Get back to your other websites, The ones you visit when you are all alone at night
Old 03-12-2014 | 11:34 PM
Mild If you were giving me good info. i am sorry. If you were messin with me I am not And you with the red cig. Is that how you do it? Just pry them off w a screwdriver ?
Old 03-13-2014 | 07:16 AM
Yup. I always whack all the retainers with a brass hammer before trying to compress the springs.
thirdchildhood is offline
