Thru transom cable sealant >
Old 03-17-2014 | 12:50 AM
Default Thru transom cable sealant
I need to replace the drive trim indicator cables. They pass thru the transom below the water line. What sealant would be best to seal the opening. 4200?
zz28zz is offline
Old 03-17-2014 | 06:45 AM
We use this caulk for all the thru-transom cables.
3M™ Marine 101 Sealant
Provides a weatherproof, watertight seal between mechanically fastened joints to resist weathering and salt water. Non-sagging, non-shrinking, remains permanently flexible.
BenPerfected is offline
Old 03-17-2014 | 09:46 AM
I like 5200
payuppsucker is offline
