Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Bilge coating is chipping off >
Old 03-17-2014 | 01:52 PM
Default Bilge coating is chipping off
The bilge coating is chipping or peeling off in the engine compartment, it's the white stuff with the black splatter paint. Any ideas on what to use to repair those areas?
senzaspectre is offline
Old 03-17-2014 | 08:20 PM
jeff32's Avatar
the coating... ??? the paint? or the fiberglass itself?
jeff32 is offline
Old 03-20-2014 | 02:12 PM
Ayuh,... Sounds like it was put on a poorly prepped surface,...
Ain't nothin' you can do 'bout it, as it'll continue to peel,...
Next time ya got the motor out, Sand everything, 'n paint it again, with Rustoleum industrial enamel,...
Bondo is offline
