smartcraft says: estop aserted what to do? 600sci
i want to start my engines ( 600sci -2008) at the pallets to check condition etc , i dint have the keys right now, i have bridged the violet and red wires , the smartcraft comes on , but the fuelpump dont start , and the smartcraft says: fuel cirk hi + trim pos cirk hi + estop asserted.
i have bridged the shifter-kables for the "neutral" and also the lanyard ( i thinked that would be the em-stop?)
maby i need to bridge mor cables in the key-sw?
regards/Marcus
regards/Marcus
I believe its really the code - EST OPEN meaning (electronic spark trigger) signal in which means ignition fault as the signal from the ecm to the ignition driver module open. Detecectable only at 0 rpm. You have a wiring problem and or coil problem.
Trim CIRCUIT HIGH IS THE TRIM SENSOR shorted - wiring or sensor problem.
fuel circuit high - fuel level sensor open. wiring problem or sensor problem.
word of warning here you have relays & fused as electrical / short protection against the ECM but really I would not be trying to hot wiring anything on your motor. The ECM's are very are sensitive about spikes/ shorts and static electricity.
hi! thanks for snwer , it stands just : " ESTOP ASSERTED" i thought that means emergency stop ? and i dont know what wires to bridge for that hehe
trim + fuel, is because i dont have that conected.
regards/Marcus
regards/Marcus
problem solved , the lynyard-sw works that the black and black/yellow conecting each other when the emergency stop is activated , and right now i dont have the key to the engine-packages i just have bought så the blavk and the black/yellow is vonnected when the key is yout , so i just separate the black/yellow in the key-sw harness , then put the violett and red together ( ign on) and then add + to the red/yellow and there we have it running
regards
regards
