idiots at the machine shop put teeth marks from vise in my rods... wtf >
Old 03-28-2014 | 08:12 PM
ratman's Avatar
Default idiots at the machine shop put teeth marks from vise in my rods... wtf
i couldnt believe it... picked up my toyota 22r engine from my local machine shop, and all four of the rods have teeth marks from the vise in them... how can they be that stupid... im just lucky they are for a 4 banger... thats why i need to go diesel or outboard down here. lol
ratman is offline
Old 03-28-2014 | 08:31 PM
Wow that's bad, at least use the brass jaw inserts lol
Unlimited jd is offline
Old 03-28-2014 | 08:53 PM
VoodooRob's Avatar
At least they used a vice, the rest is trivial.
VoodooRob is offline
Old 03-28-2014 | 09:05 PM
Now they are dimple rods.
88bullet is offline
Old 03-28-2014 | 09:10 PM
what did they need to do to the rods?
mike tkach is offline
Old 03-28-2014 | 09:33 PM
ratman's Avatar
this was supposed to be the best shop around!!!
ratman is offline
Old 03-28-2014 | 09:37 PM
ratman's Avatar
torque the rod bolts....im not a pro but have alum, alum with rubber cushions, and lead inserts for my vise... these dudes down here are idiots when it comes to building engines...
they put my crank and main bearings in the block... i yanked out the crank found some metal shavings on the main cap shoulder next to the bearing... i even lent the moron a set of long brushes to ream and clean all the oil passages in the block... i dont even think they are equipped to set valve spring pressures down here..
ratman is offline
Old 03-28-2014 | 09:56 PM
send them a picture of a rod vice,maybe they have never seen one!
Old 03-29-2014 | 05:01 AM
scarabman's Avatar
And they very well might be!
scarabman is offline
Old 03-29-2014 | 06:49 AM
Craney's Avatar
What do you wont, just remember where you live. They are not known for there machine shops.
Craney is offline
