cleaning out the shopagain parts list
Have a New bravo x upper $2850
used World Products BBC "Merlin III" Iron block; 4.5"bore needs to go 30 Bore, 9.80"-Deck never in salt water $ 1400
livorsi white on white 100 mph monster speedometer liquid filled $80
livorsi white on white engine synchronizer gauge $60
new mercruiser factory new style steering cylinder cable over hydraulic gimbal housing mount $80
2 usd msd marine engine protector rev limiters adjustable but set to 5800 rpms $70 each
new mercury racing # 840389k 5 propeller 1'1/4 prop shaft hub $80
new mercruiser flo torq II hub assembly kit 835258a 2 $50
1 hp 500 efi oil thermostat $40
1 power steering fluid cooler heat exchanger $15
1 set of slightly used gm small block 350 vortech heads
2 mercury 200 to 225 optimax 5" lower unit extension kits 25" to 30"
1 new mercruiser 7.3 diesel d tronic schwitzer turbo
