525 EFI - Coolant Change >
Old 04-02-2014 | 06:02 PM
Default 525 EFI - Coolant Change
Hello Fellas,
Is there any plugs or drains on the block somewhere to drain the coolant out to empty the system??
I want to replace it as maintenance.
Thanks in advance.
Pwraddr is offline
Old 04-02-2014 | 07:05 PM
Same place as other BBC's. Lower sides of the block between the 4/6 and 3/5 cylinders.
Griff is offline
Old 04-02-2014 | 07:11 PM
Thanks. What type of fastener is it? Size?
Pwraddr is offline
Old 04-02-2014 | 07:36 PM
Vinny P's Avatar
I hate the winter!!
its a 1/4" pipe plug, with what should be a 9/16" hex head.
Vinny P is offline
Old 04-02-2014 | 08:56 PM
Dave M's Avatar
Veteran: Navy
How often should it be changed?
Dave M is offline
Old 04-02-2014 | 09:25 PM
I always thought Dex-cool had a 5 year life, but I'm probably wrong
509 SC is offline
Old 04-02-2014 | 09:31 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It's time. 5-6 seasons, give or take; or definitely when it looses it's pink appearance and turns silver/metallic.
It will not cool as well when it starts to go as it sludges up.
Sydwayz is offline
Old 04-02-2014 | 09:54 PM
#11. Part # 22-36382 Pic of location and plug
http://www.mercruiserparts.com/Show_...nd+Camshaft%29
Griff is offline
Old 04-02-2014 | 10:20 PM
Dave M's Avatar
Veteran: Navy
I'm probably due for a change. I'll add it to the list.
Just plain old Dex-cool? I'm sure Mercury has some snake-oil equivalant for $50 / gallon.
Dave M is offline
Old 04-03-2014 | 08:00 AM
Knot 4 Me's Avatar
Plain old Dex-Cool.
Knot 4 Me is offline
