Bravo 1 upper $500 lower case $100
1990 Bravo 1 upper rebuilt w/new bearings, seals & u-joints, it is a non oiler that can be used with a later style lower by plugging the passage with a set screw locktited in place (done this before without any issues) or use with the lower case I have $500 1990 lower case standard side water inlet can be used with later model upper by plugging oil passage with a set screw locktited in place or use with the upper I have. 914-262-1898 pay-pal accepted
[ATTACH=CONFIG]521370[/ATTACH][ATTACH=CONFIG]521371[/ATTACH][ATTACH=CONFIG]521372[/ATTACH][ATTACH=CONFIG]521373[/ATTACH]
