525 EFI - fuel filter
If there is, it will be between the tanks and the spin on canister, more than likely mounted on the tall center stringer under your step panels. It looks like a giant D-cell battery with no wrapper on it.
Yes, there is. Its on the rear port side of the engine in an upright black canister.
https://www.mercruiserparts.com/Show...+And+Injectors
If you look at this picture...look at my center engine, just behind the port side rocker cover, you will see a canister with a line coming out of the left side. thats the fuel filter canister. be careful removing it.. it's plastic..
[ATTACH=CONFIG]521506[/ATTACH]
