Lots of parts, garage spring cleaning !!!!! >
Old 04-04-2014 | 05:25 PM
Default Lots of parts, garage spring cleaning !!!!!
1 one good used bravo bell housing chevrolet v/8 75.00
2 mercruiser v/6 exhaust manifolds and riser, like new freshwater 200.00 for pair
3 aluminum big block rec port intake manifold dual plane GM with brass inserts no corrosion fresh water 150.00
4 hardin marine remote oil thermostat still in box part # 625-7201 never used 150.00
5 gaffric flame arrestors for dominator 10inches in diam 2inches tall have a pair for 150.00
6 one big bmax outdrive gear lube bottle looks like it holds more than a quart with brkt 50.00
7 two power steering racks brazilian one for external back rams, one stock, both like new 100.00 each
8 four bravo shift brackets 35.00 each
9 two pair of cmi silent choice stainless diverters these go in between riser and tip to make exhaust exit thru hub, comes with hoses and air pump 300.00
10 1 bravo steering wing plate mayfair bolts to drive fasteners 150.00
11 3 502 or 454efi fuel cooler assy one still in box 50.00 each
12 lots of injectors, ecu's, distributors, throttle bodies, ect 454 502 efi
Please feel free to call or email me for pics or additional information thanks for looking
[email protected]
585-978-0391
chefke is offline
Old 04-04-2014 | 05:49 PM
do you have pic of the diverters and do you have any 496 pcm ?
tazdevil is offline
Old 04-04-2014 | 07:35 PM
No sorry no PCM for 496, leave me an e mail or text me and I can send you photos of diverters
Thanks,
chefke is offline
Old 04-16-2014 | 10:28 AM
Do can you send a picture of the wingplate? I want to make sure it will work with zeiger rams
baja200merk is offline
Old 04-16-2014 | 11:55 AM
hullofjustis's Avatar
Do you still have the wing plates?
hullofjustis is offline
Old 05-08-2014 | 03:47 PM
Would you be willing to part with an air pump from the diverters and ship it to the netherlands? Looking for a working pump set for my silent choice system.
dheruer is offline
Old 03-05-2015 | 08:49 PM
Can you send me pics of the shift brackets? [email protected]
Schiada 30 is offline
Old 03-06-2015 | 06:25 AM
Can you send me Picts of the merc v6 manifolds and Bmax lube bottle please.
[email protected]
Thanks Kevin
lucky cat is offline
Old 03-07-2015 | 05:45 PM
hammerdown500's Avatar
Pics of the bravo bell housing please
hammerdown500 is offline
Old 03-07-2015 | 07:04 PM
Oops... Just noticed this add was posted last year..
