Yellowing gel
What is the best way to restore the bright white color on my hull sides? You can see where the original painted graphics where on the boat. The boat is all white right now and I have tried 3m super duty and it didn't make a difference. What is the easiest and safest way to restore the gel? Thanks
What grit sand paper did you start and finish with before buff. Did you use a long board with water? My gel is already getting thin in a few spots as well, I will have to be carful when sanding and buffing
