Where is the Thermostat? >
Old 04-09-2014 | 06:44 AM
Default Where is the Thermostat?
I have a 1994 Cigarette Top Gun with supercharged 600 Hawks. Where is the thermostat? Is there one?
UrbanDisturbance is offline
Old 04-09-2014 | 07:02 AM
If there is one it should be under the water distribution block that feeds your headers
endeavor1 is offline
Old 04-09-2014 | 09:15 PM
I Have an enclosed system with blowers. the thermostat is not in the intake, it is on the remote fill where the radiator cap is. It is a threaded cast 2 piece with multiple ports.
It also has the temp sensor in that cast block.
cruis is offline
Old 04-10-2014 | 06:51 AM
http://www.mercruiserparts.com/Show_...sed+Cooling%29 this might help...
TWIN-SPINS is offline
Old 04-10-2014 | 07:21 AM
I don't have a closed cooling system. I followed the water hoses and I can't see anything that indicated a split in water flow. I guess I don't have one. After the water pump, I goes through the oil cooler and directly into the engine. After that, I can't see anything.
Old 04-10-2014 | 08:53 AM
Brad Zastrow's Avatar
You probably do not have them. Do not want them or need them in a blower motor.
Brad Zastrow is offline
Old 04-10-2014 | 04:07 PM
You`ll only have a thermostat if you have A/C.. hope this helps
NEXT!!
ICDEDPPL is offline
Old 04-11-2014 | 06:29 AM
I don't have one. Thanks for trying to help.
