502 MPI Temp Sensor >
502 MPI Temp Sensor
502 MPI Temp Sensor
Old 04-09-2014 | 09:10 PM
Default 502 MPI Temp Sensor
Hey guys, I have a 502 mpi with mefi3. I have crossover with bypass and I am curious to know what guys with this set up or with a crossover without bypass are doing to run there temp sender for gauge and temp sensor for computer. I have the temp sender in the front of the intake, but don't have a spot for the temp sensor. I heard you can put a resistor in the temp sensor plug to make the computer see a constant temp, but not sure how good of a solution that is. I would imagine anyone with a crossover and a mefi3 would have had to take care of this situations. What's the best way to handle this?
ealesh33 is offline
Old 04-10-2014 | 07:08 AM
http://www.cpperformance.com/p-12882...et-spacer.aspx
I am using this. Worked great when I was running my MPI setup. Using it again on my Holley EFI setup.
Gimme Fuel is offline
Old 04-10-2014 | 07:18 AM
So you ran both your temp sender for your gauge, and your temp sensor for computer in the 2 outlets?
ealesh33 is offline
Old 04-10-2014 | 08:57 AM
Unfortunately that spacer won't fit on mine. I only have about 1/2" of clearance between my t stat housing and fuel pressure regulator
ealesh33 is offline
Old 04-10-2014 | 09:53 AM
yes I did. Oh, I had removed that Schraeder valve on the end of my fuel rail and just made a block off plate because I was pushing 62 psi to my injectors and didn't want it blowing fuel into my plenum. The fuel regulator is actually down on the pump.
Old 04-10-2014 | 11:21 AM
My adjustable regulator is right there on the plenum
ealesh33 is offline
Old 04-10-2014 | 02:02 PM
Ah, I had older MEFI1 (circa 1997) unit. Much changed between yours and mine and the Cool Fuel system configuration.
