Attention stepped Fountain owners-props turning in or out? >
Old 08-16-2002 | 12:52 PM
Fast Frank
Default Attention stepped Fountain owners-props turning in or out?
2002 42 Fountain, props turn in from the factory-always heard that this gives you 1-3 mph, but takes away handling.
On the "History of cat's" thread there was an extensive discussion of the do's and dont's of spinning in or out. The bottom line was it is much more dangerous spinning in, like this boat came from the factory.
Can someone explain the reasoning here?
Anyone tried to or have them spinning out? (good or bad results?)
Old 08-17-2002 | 02:27 AM
candyman35's Avatar
You'll lose 3-4 mph. The boats are setup from Fountain to run in. To run them out you would have to mess with the X dimension. The only place I have noticed handling problems is around the dock.
Dan
candyman35 is offline
Old 08-17-2002 | 02:54 AM
sean stinson's Avatar
The Illustrious One
Veteran: Navy
The reason it is ill handling around the dock is because the boat is the prop is fighting the boat for lack of a better phrase. They are running against each other so in my unprofessional opinion it's because the left is on the right and vice versa so the torque from the engine is making it do stupid things......but if you get in tight quarter's DON"T PANIC if it does something backwards a boat bumping another in neutral is better than bumping one in gear under power. I have found that the comfort zone for myself is instead of putting say the outside engine in reverse to pull it into the dock put the inside engine in reverse and more times than not, again for me, it has had the same effect as the outside engine did on outward rotation.... I am sure that explaination won't get me honors for the graduation, but it's Friday night at midnight with visions of Spearmint Rhino's in my head.
Dying,....Is the day worth living for!!!!!!
sean stinson is offline
Old 08-17-2002 | 03:41 AM
Step's Avatar
Have not tried rotating out, but can't believe handling would be much better (if any) when running. Maneuvering around dock possibly. Another factor would be a staggard setup. Around the dock, you have to be a little more patient waiting for the bow to start coming around. Feels like the boat tends to slide rather than turn-in-place.
Step is offline
Old 08-17-2002 | 02:38 PM
The Illustrious One
Veteran: Navy
Out doesn't give you any more handling while running just manuvering around the docks and such. IMHO
Rebel_Heart
Prop Talk
6
05-25-2008 04:46 PM
bshzba
3
08-20-2007 11:45 PM
klaw
07-28-2006 05:00 AM
drgnrydr
Prop Talk
5
06-20-2006 01:08 PM
VIPER7
Sonic
4
12-09-2004 08:37 AM
