FS: WICKED MARINE Crossfire Dual Port Drive Shower $100 >
Old 04-15-2014 | 05:30 PM
Default FS: WICKED MARINE Crossfire Dual Port Drive Shower $100
I recently purchased this drive shower from my Bravo but have since added hydraulic steering and this wont fit. This hasn't been used, but has been mounted on the drive for a test fit. I had it powder coated a CANDY PURPLE, but it could be easily painted or re-powder coated to the color of your choice. $100 + shipping
" This shower/cooler has out performed every competitor's drive shower/cooler tested to date. Has specially designed and tested pick ups that forces the water up the tubes and with the help of the redesigned dump ports, sprays the water across the drive in a fan pattern the water is contacting more of the drives hot surface. Pick-up ports are adjustable up to 1-1/2 inches. With Just Wicked Marine’s Shower/Cooler design you get more water flow and lower drive oil temperature. This Shower/Cooler has 3 times the water flow than other very popular shower cap designs and has a 15-35 degree lower drive oil temp" CP PERFORMANCE
MCKILLOP is offline
Old 04-16-2014 | 11:37 AM
bump
MCKILLOP is offline
Old 04-21-2014 | 11:31 AM
Bump
MCKILLOP is offline
