2 Quart Filter with Anti Drain Back - Where can I get them?
I currently use the K&N HP 3002 and thought it would be nice to upgrade to a 2 quart filter with anti drainback. But I cant find them... Cant believe nobody offers it.
Anybody know where to get them? Have to have anti drainback as I have an inverted filter and assume this would hinder dry starts if the 2 quarts has to fill every time it starts.
Ayuh,.... Wix makes Alota filters for that housin',....
Not sure of the part number shown, but I'm sure you can get a filter with, or without, in 'bout any capacity ya want, from a pint to a couple quarts,...
Napa filters are rebadged Wix filters,... hence the similar part numbers,...
I sent an e-mail to Donaldson, I use their P550832 to find out if it has an anti-drain back. They make the filters for Amsoil and are a very high quality synthetic filter media. I've been using them for years and the oil comes out almost the same as it goes in.
They dont have a drainback valve:
Detailed Description
For High Performance, Racing Applications - Not for Street Use
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 7.82 in.
Outside Diameter (Top): 3.6 in.
Thread Size: 13/16-16
By-Pass Valve Setting (PSI): None
Max Flow Rate: 28 GPM
Gasket Diameters
Outside Diameter: 3.444 in.
Inside Diameter: 3.100 in.
Thickness: 0.260 in.
Additional Details
Anti-Drainback Valve Included: No
Service: Lube
Type: Full Flow
Media: Paper
Height: 7.82 in.
Gasket Diameters
Additional Details
