Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
HOT FRIDAY SUPER SALE!! Crossfire Dual Port  Alpha, Bravo, Drive Showers >
Old 04-18-2014 | 04:01 PM
KEPP's Avatar
Only the Best Will Do!
Cool HOT FRIDAY SUPER SALE!! Crossfire Dual Port Alpha, Bravo, Drive Showers
Mayfair Performance's newly designed Multiport Crossfire Drive Shower/Cooler kits bring drive shower technology to a new level. Thanks to the two specially designed adjustable mounting clamps ,this shower/cooler will fit Alpha One, Alpha One Gen Two, Bravo One, Two and Three.
Comes with full color illustrated installation instructions.This shower/cooler has out performed every competitor's drive shower/cooler tested to date. Has specially designed and tested pick ups that forces the water up the tubes and with the help of the redesigned dump ports, sprays the water across the drive in a fan pattern the water is contacting more of the drives hot surface. Pick-up ports are adjustable up to 1-1/2 inches. With Mayfair Performance's Shower/Cooler design you get more water flow and lower drive oil temperature.
What should you be cooling and why?
The component inside the stern drive that is most susceptible to abuse from heat is the oil. It begins to break down at about 300 degrees. The metal components inside the drive can reach temperatures of at least three times that amount before they become affected. The only way the drive components can reach those temperatures is if the oil has broken down and the heat generating friction builds up. If you cool the oil and keep it from breaking down, it will cool and protect the components inside the drive. Now you should be asking, why do most drive cooler manufacturers target the top bearing cap? There is still one more reason to ask the same question
We will be running this sale until next Friday 04/25/14 PM ME For OSO Membership pricing!
KEPP is offline
Old 04-19-2014 | 12:02 PM
KEPP's Avatar
Easter Weekend bump, PM ME for OSO Membership pricing.
KEPP is offline
Old 04-21-2014 | 11:20 AM
KEPP's Avatar
PM's replied, Get your special OSO price today, PM me with zipcode for price!
KEPP is offline
Old 04-21-2014 | 11:23 AM
Will this fit a xr with Ziegler dual ram external steering?
Padraig
Padraig is offline
Old 04-22-2014 | 08:50 AM
KEPP's Avatar
Padraig
Padraig,
It will not work for you application.
Tuesday Bump, PM me for OSO Member pricing!
KEPP is offline
Old 04-25-2014 | 04:51 PM
KEPP's Avatar
Blowout sale on the crossfire drive showers, PM me for your price.
All PM's replied.
KEPP is offline
Old 04-25-2014 | 06:05 PM
Thanks,
Padraig
Padraig is offline
Old 04-25-2014 | 08:25 PM
08205 twin alphas...
msher44 is offline
Old 04-30-2014 | 10:41 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
I sent you a PM on 4/28 . Anybody home ?
the deep is offline
Old 04-30-2014 | 07:24 PM
Quote for twin alpha setup in 08205?
msher44 is offline
