To stat or not to stat that is the question >
Old 04-21-2014 | 05:17 PM
Default To stat or not to stat that is the question
I have 454 with pro chargers and cross over kits.
The T stat housing just has two ports each to x manifold.
At the crossover there is a bypass to the intetcooler.
It had no stats when I bought it.
I was going to install 143 high flow stats but will the exhaust get too hot before the stat opens
schurgervt is offline
Old 04-21-2014 | 05:29 PM
swan2's Avatar
I would say no thermostat.
swan2 is offline
Old 04-21-2014 | 07:34 PM
You need bypass to get water to the exhaust if you are using t-stat, in my application i have try t-stat and cross over with bypass without success, they made steam poket in the block and the stat dont open at the right time, you need to drill min 3 to 4x 3/16 hole in t-stat to help with temp consistency.
supermx96 is offline
Old 04-23-2014 | 03:51 PM
inspector747's Avatar
Even with the bypass you still had to drill holes in the tstat.... I have the Hardin with bypass and now i am thinking from your post I need to drill holes in mine.
thanks
Bryan
inspector747 is offline
Old 04-23-2014 | 05:47 PM
Why take the chance? What does it take to clog a 3/16" hole? If clogged, no you're back to steam pockets....
Ditch the tstat when running x-o
thanks
Bryan
commandersander is offline
Old 04-23-2014 | 06:18 PM
Have to run the stat, otherwise I don't get any temp.... To much water flow even with a restrictor plate... Only saw 110 at wot.
Old 04-23-2014 | 07:06 PM
I have never got a 3/16'' hole clog in t-stat in 3 years with that setup without sea strainer, 3/16'' hole is prety big, you do not need only 1 hole but you need minimum 3 hole in the stat to make consistency.
Old 04-25-2014 | 08:10 AM
I ran stats two years ago, and none last year. I think I need to restrict alittle water to the exhaust. The flow thru the inter coolers without stats is low.
indysupra is offline
Old 04-26-2014 | 10:17 AM
procharger says no thermostats...
ezstriper is offline
