Cam and exhaust set up question (reversion) >
Old 04-27-2014 | 11:46 AM
Default Cam and exhaust set up question (reversion)
I'm having a motor put together and was going to run a schneider .646 lift cam with in. Duration (.050) 258 ex duration (.050) 270 and a 110 lobe seperation, it will be wet exhaust but imcos with the "s" riser so the water will dump in pretty far back and below the exhaust ports height wise, do you think I will have any reversion issues? Any other input on this cam set up? Thanks
Bbeck is offline
Old 04-27-2014 | 12:10 PM
I'd say pretty good possibility with that cam. How big is this engine??
MILD THUNDER is offline
Old 04-27-2014 | 12:13 PM
468ci. And pretty good possibility I will have issues?
Bbeck is offline
Old 04-27-2014 | 12:26 PM
That is a huge cam for a 468ci. You will be very lucky if it does not revert water.
Griff is offline
Old 04-27-2014 | 12:27 PM
Aim for something closer to 114 LSA if you plan on keeping wet exhaust.
offshore312 is offline
Old 04-27-2014 | 12:43 PM
Thanks for the input fellas, do you think this cam would work well? I'd like to make as much power as possible without having issues and break downs
COMP Cams Xtreme Marine Camshaft Hydraulic Roller BBC Gen VI 454 .566"/.566" 2,800-6,200 RPM Operating Range
Bbeck is offline
Old 04-27-2014 | 12:44 PM
Sorry the link didn't work right, it's a 112 lsa
Bbeck is offline
Old 04-27-2014 | 12:46 PM
Look at this on eBay:
http://pages.ebay.com/link/?nav=item...d=390823011169
Bbeck is offline
Old 04-27-2014 | 12:56 PM
Don't think you'll like that RPM range. Remember, you don't have a stall speed converter to help. You're going to want to be into the power before 2800 rpms
Old 04-27-2014 | 01:16 PM
What heads are you using?
Unlimited jd is offline
