10 Meter Updating
Old 04-28-2014 | 11:14 PM
Default 10 Meter Updating
Hello all you "Fountain-heads", wanted to share some updating to my 89' 10 Meter. Started with a blank canvas, had a few ideas but nothing in stone. Wanted to update the exterior, dash and cockpit carpeting to start with. [ATTACH=CONFIG]522725[/ATTACH]
poiuy10 is offline
Old 04-28-2014 | 11:26 PM
Had a few years of dock rash repaired, nothing serious.... just cosmetics. They found a little "extra" that some pirates took off the boat. Wishing It was still on the boat.... hydraulic steering ! I had that look on my face... you know when you see your own car on blocks after some fool done stole your 22"s. #$@%&
Attached Thumbnails 10 Meter Updating-img_2268.jpg   10 Meter Updating-img_0889.jpg   10 Meter Updating-img_8301.jpg
poiuy10 is offline
Old 04-29-2014 | 09:12 PM
Here is a shot of the cockpit before, all original to the boat.... except the totally narly engine synch. ( black box to the right of the compass ) Actually worked until it was unhooked last season. Any takers on the synchronizer... ? :drool1
poiuy10 is offline
Old 04-29-2014 | 09:21 PM
Took a shot of the dash apart... the crew said it wasn't too badly chopped up behind the panel. Fountain did a pretty good job of wiring a boat perhaps. Had the new Livorsi gauges sitting in the garage for four years, before getting around to installing them.
Attached Thumbnails 10 Meter Updating-20140222_093354.jpg   10 Meter Updating-20140222_093345.jpg   10 Meter Updating-20140222_093510.jpg
poiuy10 is offline
Old 04-29-2014 | 10:14 PM
Went to install the new gauges in the freshly painted dash and found this... semi-circle scratches on the lenses. ( at the right angle of light, the scratches really showed up ) Guessing it came from the press, putting the gauges together. Have to applaud Tony at Livorsi, he fixed me up with brand new lenses and he had the gauges back to installer within the week.
Attached Thumbnails 10 Meter Updating-img_6367-1.jpg   10 Meter Updating-img_4534.jpg
poiuy10 is offline
Old 04-29-2014 | 10:28 PM
Had an idea for the dash... sent a rendering to the painter. What do you guys think, too much, not enough ??
Wanted to get rid of the speedometer gauge, feeder line was always clogged up and didn't like it. Adding a garmin gps unit to replace the gauge; wanted to place the garmin in the same place as the gauge but the painter had a better idea....
poiuy10 is offline
Old 04-30-2014 | 08:27 AM
Not sure if you are aware, but Fountains had plugs on those gauge harnesses, and switch harnesses. Meaning that you can reach into the side where all the wires go into, and unplug like 4 or 5 plugs, and remove the entire dash with the gauges, switches, etc intact. Build the dash on the workbench, then plug it all back into the connectors
MILD THUNDER is offline
Old 04-30-2014 | 09:17 AM
TomFTM's Avatar
here is the dash I did on my 88 10 meter , I sold the boat last sept.
TomFTM is offline
Old 04-30-2014 | 04:35 PM
Nice ride! I love the lines on the 10 meter. Keep posting pics! I got ride of my pitiot tube speedo on my boat this winter and mounted a Garmin 640 in the new dash.
Sunrocket24 is offline
Old 04-30-2014 | 06:40 PM
And each side is marked with tape, green on one side blue on the other. Don't make the mistake I did and think the tape was for holding the plugs together, I tore it off in the dark and wadded it up. How many possible combinations do 10 connectors (5 each side) make? That was a nightmare
4bus is offline
