need quality parts
Old 04-29-2014 | 05:39 PM
Default need quality parts
I have a 32 foutain 2000 with twin 502s stock I want to replace spark plugs caps rotors and wires. I need to know what type of quality parts I should buy part numbers would help, I dont even know what type of plugs I should run. Had the boat 2.5 years figure those are well over due by now. Been putting it off becuase plugs look really hard to change. I did a bilge pump last year and that was a project in itself.
TOMMY22555 is offline
Old 04-29-2014 | 07:20 PM
Just go to mercruiser website... Should have diagrams and part numbers as well as recommended plug types, etc...
msher44 is offline
Old 05-01-2014 | 01:18 AM
Spark Plugs are NGK BR6FS. You can get them at any auto parts store.
The Sierra Marine Ignition stuff is just as good as Merc stuff and cost much less.
Cap & Rotor kit http://www.go2marine.com/product/159...-808483q2.html
Griff is offline
Old 05-01-2014 | 08:29 AM
thank you
Old 05-01-2014 | 06:50 PM
I have not had trouble with stock Mercury parts but I now use these marine parts from Summit.
ACC-8132 cap and rotor - brass terminals don't oxidize like stock aluminum ones do
MSD-31489 plug wires - high quality but a couple of the lengths seem tight(short?)
NGK-2623 spark plugs BPR6FS - projected nose plugs give me a better burn
My 502 is the same model as yours. Yes 502 Mag MPI.
dbkski is offline
Old 05-01-2014 | 07:40 PM
SB
x 2 on brass terminals vs stock GM/Merc asluminum ones.
BTW, what kind of 502? There are a few variations. MPI Black/ Blue/Carb/Supercharged.
SB is online now
Old 05-01-2014 | 08:36 PM
Mpi black
Old 05-01-2014 | 09:08 PM
Sierra uses brass. I'm generally not a big fan of Sierra stuff, but the ignition stuff is pretty good.
Griff is offline
Old 05-02-2014 | 09:32 AM
KEPP's Avatar
Only the Best Will Do!
http://www.keitheickert.com/p-13771-...x-tapered.aspx
http://www.keitheickert.com/c-142-ignition-systems.aspx
KEPP is offline
