Engine heating up >
Engine heating up
Engine heating up
Old 05-02-2014 | 11:47 AM
Question Engine heating up
One of my engines at mid to high rpm's is heating up to 170/180, what should i check ??
bayareadave49 is offline
Old 05-02-2014 | 12:20 PM
Ayuh,.... Change the Impeller,....
It's Always the 1st place to look, in Any overheat situation,...
Bondo is offline
Old 05-02-2014 | 02:32 PM
If impeller is good, make sure you check the housing as well. You may want to take the thermo out and put it in hot water to make sure it is working right, or replace. If those three things are good move on to oil cooler being blocked by old pieces of impeller (end caps are easily removed). Next is scale from salt water use that may release and clog ports around thermo, recirculating pump, exhaust, causing poor flow. And last is the fitting between drive and transom can sometimes become clogged, collapse, or have a small leak that reduces flow.
4bus is offline
Old 05-02-2014 | 03:10 PM
Dave M's Avatar
Veteran: Navy
What engine? 170 for a MPI engine sounds about right.
Dave M is offline
Old 05-02-2014 | 06:08 PM
Also interested. New impeller, new recirc pump, and still 5-7 psi at anything above idle.
also cleaned the water pressure gauge sense line.
Cole2534 is offline
Old 05-02-2014 | 09:58 PM
Check for an obstruction or some debris at the entrance to the oil cooler.
Griff is offline
Old 05-03-2014 | 12:27 AM
how old are the elbows and risers?they could be rusted up real good,causing a restriction.
sutphen 30 is offline
Old 05-03-2014 | 05:59 AM
All good info. guy's thanks and it's 5.7 mpi's that im running.
Old 05-03-2014 | 06:56 AM
Dave M's Avatar
Veteran: Navy
Pretty sure that motor runs a 160* t-stat.
Dave M is offline
Old 05-03-2014 | 11:33 AM
It was packed full of impeller and a few small rocks.
I'd probed it before, from the top, and it felt like rubber so I ASSumed that was the hose on the bottom. Fast forward to today and I finally managed to remove bottom hose and immediately chunks fell out.
Moral of the story- don't be lazy.
Cole2534 is offline
